Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Hello There,
i have implement a small project on my rasspberry pi to send it's temperature to thingworx platform successfully.
i have done this using LUA script, but i need to do the sam using java (E-SDK).
can any one help me with that or tell me where to start ?
thanks in advance .
Hey Mohamed,
Is there something specific you have questions about or need examples for? There is a Java SDK quickstart guide on the developer zone, and there are sample projects included with the Java SDK for a simple sensor and a steam sensor; this is where I would start.
-James
Hey Mohamed,
I was also able to find this Academic program guide that is specifically around reading Raspberry Pi data using the Java SDK. Hopefully this is helpful!
https://www.thingworx.com/ecosystem/academic-program/iot-projects/weather-app-raspberry-pi/
-James
thanks a lot Games.
i will check this but is there anything more simple as the examples in this link is a little bit advanced.
The project files are included at the bottom of the Academic post -- it should be as simple as downloading this project, building it, and running the executable jar on your Raspberry Pi as such:
java -jar ./temperature-thing-jar-with-dependencies.jar thingworxURI appKey simulated`
where thingworx URI is your URI and appKey is your app key.
Let me know if you're running in to issues; the only other change you may need to make is around whether your twx server is using SSL and/or self-signed certificates.
