Embed mashup in other web page
MrPark
3-Newcomer
I have a mashup link: https://academic-educatorsextension.portal.ptc.io/Thingworx/Mashups/sw_make_panel_MrPark?appKey=f254750f-a512-4150-ac0b-5e3fd6b3c1fa&x-thingworx-session=true
I'm trying embed this page with this code:
<iframe src="https://academic-educatorsextension.portal.ptc.io/Thingworx/Mashups/sw_make_panel_MrPark?appKey=f254750f-a512-4150-ac0b-5e3fd6b3c1fa&x-thingworx-session=true" width="650" height="600" scrolling="auto"> </iframe>
but I get empty form:
4 REPLIES 4
What's your ThingWorx log saying and when you access this page, what's your F12 composer console saying?
It could be a security issue related to the origin.
I'm not sure if you have access to configuring the Academic instances - but maybe these articles explains more around the topic:
https://www.ptc.com/en/support/article?n=CS181456
http://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/#page/ThingWorx%2FHelp%2FSecurity%2FAllowingEmbeddedMashupsiniFrames.html%23
Cheers,
Michael
slangley
23-Emerald II
(To:mneumann)
Hi @MrPark.
If one of the previous posts helped to resolve your issue, please mark the appropriate one as the Accepted Solution for the benefit of others with the same issue.
Thank you for using our Community!
--Sharon
eferent
(To:MrPark)
Try to inspect the page headers that come from the ThingWorx server.
It might be because you have the following headers sent: ClickjackFilterDeny and ClickjackFilterSameOrigin.
If this is the case, check the server side configuration here: http://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/#page/ThingWorx%2FHelp%2FSecurity%2FAllowingEmbeddedMashupsiniFrames.html%23
Emil
