Enabling checkbox 'Automatically update values' of get properties, parameters not passing in runtime
MM_10159448
Hi Team,
I am facing problem somehow similar to this topic.
Problem is ,I am using widget mashup container and thing with get properties to get data from properties, passing mashup name to container mashup though menu in the mashup as well as some some other parameters to containers,
using 2 properties with subscription service in the thing.
but facing below issue.
Issue 1- when enabling checkbox "Automatically update values" of get properties, parameters not passing in runtime to container mashup
Issue 2-when unchecking checkbox "Automatically update values"  of get properties, parameters passing in runtime to container mashup
Can you please provide reason and solution on this?
My requirement is to keep checkbox enabled and parameter should pass to container mashup in runtime.
Maybe you also need to run the "Refresh" action on the contained mashup,
