Nov 3, 2020 12:04 PM UTC
Entities become non-editable after deployment as an extension.
I'm deploying Thingworx entities as an git extension from Dev to test server, which makes entities non-editable.
i.e xml of entity will have new tag as <aspect.isExtension="true">.
As well as DELETE option is disabled.
I have already tried removing this tag and save xml and re-import but no luck.
How to revert or make that entity editable again?
Nov 3, 2020 10:17 PM UTC
Hello @TanmeyTWX ,
I believe your answer is:
TanmeyTWX17-PeridotAuthor
Nov 5, 2020 2:41 PM UTC
Hi PEHOWE,
@posipova
I tried below steps but Entity is still non-editable and delete option is disabled.
1. Exported the ThingShape xml.
2. Added aspect.IsEditableExtensionObject="true"
3. Save it.
4. Import back this ThingShape to Composer.
I'm good if I get the DELETE option working even. I can delete it and create again.
Thingshape definition attached for reference.
