Hello everyone,
I've been trying to create 'Thing' in a batch mode, and I've decided to use the Resources["EntityServices"] CreateThing().
The service seems to work as intended. However, I can verify that the 'Thing' properties of my newly created Thing do not have the 'Default Values' I have configured. Has anyone had an issue with this in the past?
Note: I'm using v8.4.1
For your reference , this is the service code I am using
var text = '';
var characters = 'ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789';
for ( var i = 0; i < 6; i++ ) {
text += characters.charAt(Math.floor(Math.random() * i));
try {
var params = {
name: text /* STRING */,
description: undefined /* STRING */,
thingTemplateName: 'MyThingTemplate' /* THINGTEMPLATENAME */,
tags: undefined /* TAGS */
// no return
Resources["EntityServices"].CreateThing(params);
catch (err)
logger.warn (err.message);
try {
Things[text].EnableThing();
Things[text].RestartThing();
catch (err)
Please define ThingTemplate with name "MyThingTemplate" with default property values before using above service code.
Are you creating Thing from specific ThingTemplate which have some properties with default values ? If you are creating thing from Generic Thing template, then how you are setting default property values on thing . Please share that code.
Hello @vinakumar ,
I'm creating a thing from a specific ThingTemplate which has some properties with default values.
I am not seeing any issue at my end in seeing the default property values for Things created dynamically.
Hi
As of now I tested on version 8.4.5 and found it working for me . Will test on 8.4.1 version too.
Yes it is working for me on 8.4.1 too .
Please open tech support case to investigate your entity and service code you are using .
var text = '';
try {
var params = {
// no return
catch (err)
try {
catch (err)
