Error SSL handshake when connecting Edge CSDK to Thingworx
AliBenBelgacem
I have two thingworx (9.3.4) running on 2 differents containers.
1- Container 1 is configured on port 80:8080 (NO_TLS = TRUE)
2- Container 2 is configured on port 8081:8080  (NO_TLS = TRUE)
From my host machine, i run an edge csdk
it works perfectly with the first container (port 80) [See log OK]
With the second container, i have an error  TW_NEW_SSL_CLIENT: SSL handshake error. Consider verifying you have compatible SSL ciphers, Error was: error:0A00010B:SSL routines::wrong version number. [See log KO]
I tried to update the configuration of tomcat but it didn't work
Do you have any idea how to use any port except 80 to run the edge
Thank you for your help.
Ok, I find a way to bypass this issue.
I deployed my csdk in another container, I put my edge container in the same network as my thingworx container. So i don't need to forward port.
I always use port 80. I have just to change the network and the ip if i want to change the thingworx container.
PortNavigator Docker Desktop extension allow to do this easly
About this error - "TW_NEW_SSL_CLIENT: SSL handshake error. Consider verifying you have compatible version number": https://www.ptc.com/en/support/article/CS387747
Hi @AliBenBelgacem,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina
PTC Community Moderator
PTC
If it is possible, you can test it by configuring your Container 2 to use port 80 also, it will help to verify if it is related to the port or not.
