We are using the FileUpload widget in which the MaximumFileSize property value is set to 2000MB. When the file size goes beyond this a status message is displayed at runtime.
In this message an error code is embedded which we want to hide.
The status message is as below:
ABC is larger than the maximum allowed, 2000MB
We want to hide , from this message.
If anyone knows how to do it please help. We are using ThingWorx 8.5.4-b222.
Hi @PG_CG ,
you may need to upgrade ThingWorx to avoid such encoding issue.
Here I found a similar reported in an Article:
Hi @PG_CG ,
