Error connecting Raspberry EMS to Thingworx Composer
OscarD
1-Newbie
I just installed the EMS on my Raspberry Pi, following the steps in https://developer.thingworx.com/resources/guides/thingworx-raspberry-pi-quickstart/launch-ems I created a config.json file in order to bind it to my Thingworx composer running on another computer in my local network but I have some issues.
Hi I am having the following errors in debug:
[INFO ] 2017-10-30 20:41:46,44 ./wsems: Using config file: /home/pi/Desktop/microserver/etc/config.json
[FORCE] 2017-10-30 20:41:46,45 ./wsems: Starting up ....
[FORCE] 2017-10-30 20:41:46,46 ./wsems: Initializing EMS ....
[FORCE] 2017-10-30 20:41:46,46 main: Using config file /home/pi/Desktop/microserver/etc/config.json
[INFO ] 2017-10-30 20:41:46,46 ./wsems: Creating the WsEms proxy.
[INFO ] 2017-10-30 20:41:46,46 ./wsems: Starting HTTP Server.
[INFO ] 2017-10-30 20:41:46,46 ./wsems: Initializing the ThingWorx REST interface.
[FORCE] 2017-10-30 20:41:46,46 httpServer:
[DEBUG] 2017-10-30 20:41:46,47 httpServer: http server bound to port=8080.
[DEBUG] 2017-10-30 20:41:46,48 SDK: twWs_Create: Initializing Websocket Client for 192.168.15.166:8080/Thingworx
[DEBUG] 2017-10-30 20:41:46,48 SDK: twTlsClient_Create: Initializing TLS Client
[DEBUG] 2017-10-30 20:41:46,49 SDK: twApi_Initialize: Websocket Established after 0 tries
[DEBUG] 2017-10-30 20:41:46,49 SDK: subscribedPropsMgr_Initialize: Initializing subscribed properties manager
[DEBUG] 2017-10-30 20:41:46,49 jsonConfigurator::getJsonEntity: Key cert_chain not found
[DEBUG] 2017-10-30 20:41:46,49 jsonConfigurator::getJsonEntity: Key validation_criteria not found
[DEBUG] 2017-10-30 20:41:46,49 jsonConfigurator::getJsonEntity: Parent file not found
[DEBUG] 2017-10-30 20:41:46,50 SDK: twTunnelManager_Create: Tunnel Manager singleton already exists
[DEBUG] 2017-10-30 20:41:46,50 WsEmsProxy::bindThing: Host specified as 'localhost'.  Testing IPV6/IPV4 connectivity
[WARN ] 2017-10-30 20:41:46,53 WsEmsProxy::bindThing: Exception connecting to localhost:8001.  Err: Connection refused [localhost:8001]
[WARN ] 2017-10-30 20:41:46,53 WsEmsProxy::bindThing: Changing host from 'localhost' to '127.0.0.1'
[DEBUG] 2017-10-30 20:41:46,54 SDK: added PiThing to boundList
[DEBUG] 2017-10-30 20:41:46,54 SDK: twApi_BindThings: not currently connected, only binding things to api
[DEBUG] 2017-10-30 20:41:46,54 SDK: twMessage_Delete:  Deleting BIND Message: 1
[DEBUG] 2017-10-30 20:41:46,54 jsonConfigurator::getJsonEntity: Parent file not found
[INFO ] 2017-10-30 20:41:46,54 wsEmsProxy::initialize: Initialization complete!
[INFO ] 2017-10-30 20:41:46,55 ./wsems: Starting the connection.
192.168.15.166:8080-->[DEBUG] 2017-10-30 20:41:46,57 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-10-30 20:41:46,58 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-10-30 20:41:46,266 SDK: twWs_Connect: Error initializing web socket.  Response code: 400
[DEBUG] 2017-10-30 20:41:51,267 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-10-30 20:41:51,267 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-10-30 20:41:51,477 SDK: twWs_Connect: Error initializing web socket.  Response code: 400
[DEBUG] 2017-10-30 20:41:56,477 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-10-30 20:41:56,477 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-10-30 20:41:56,706 SDK: twWs_Connect: Error initializing web socket.  Response code: 400
[DEBUG] 2017-10-30 20:42:01,707 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-10-30 20:42:01,707 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-10-30 20:42:01,927 SDK: twWs_Connect: Error initializing web socket.  Response code: 400
[DEBUG] 2017-10-30 20:42:06,927 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-10-30 20:42:06,927 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-10-30 20:42:07,157 SDK: twWs_Connect: Error initializing web socket.  Response code: 400
[DEBUG] 2017-10-30 20:42:12,157 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-10-30 20:42:12,157 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-10-30 20:42:12,372 SDK: twWs_Connect: Error initializing web socket.  Response code: 400
[DEBUG] 2017-10-30 20:42:17,372 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-10-30 20:42:17,373 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-10-30 20:42:17,586 SDK: twWs_Connect: Error initializing web socket.  Response code: 400
[DEBUG] 2017-10-30 20:42:22,587 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-10-30 20:42:22,587 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-10-30 20:42:22,807 SDK: twWs_Connect: Error initializing web socket.  Response code: 400
[DEBUG] 2017-10-30 20:42:27,807 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-10-30 20:42:27,808 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-10-30 20:42:28,26 SDK: twWs_Connect: Error initializing web socket.  Response code: 400
[DEBUG] 2017-10-30 20:42:33,27 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-10-30 20:42:33,27 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-10-30 20:42:33,255 SDK: twWs_Connect: Error initializing web socket.  Response code: 400
[DEBUG] 2017-10-30 20:42:38,255 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-10-30 20:42:38,256 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-10-30 20:42:38,487 SDK: twWs_Connect: Error initializing web socket.  Response code: 400
[DEBUG] 2017-10-30 20:42:43,487 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-10-30 20:42:43,488 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-10-30 20:42:43,703 SDK: twWs_Connect: Error initializing web socket.  Response code: 400
[WARN ] 2017-10-30 20:42:46,103 Main: Unable to connect to server.  Trying .booted config file
[WARN ] 2017-10-30 20:42:48,702 WsEmsProxy::execute() : Server connection failed.  Error Code: 201
[FORCE] 2017-10-30 20:42:51,205 Main: Shutdown signal received. Restarting ....
[DEBUG] 2017-10-30 20:42:51,206 SDK: twMessage_Send: Not authenticated yet
[ERROR] 2017-10-30 20:42:51,206 SDK: twMessage_Send: Error sending Message with RequestId 2
[ERROR] 2017-10-30 20:42:51,206 SDK: twApi_UnbindThing: Error creating sending Unbind message
[DEBUG] 2017-10-30 20:42:51,206 SDK: twMessage_Delete:  Deleting BIND Message: 2
terminate called without an active exception
My config.json file is:
    "ws_servers":   [{
            "host": "192.168.15.166",
            "port": 8080
    "resource": "Thingworx",
    "http_server":  {
        "host": "127.0.0.1",
        "port": 8080
    "appKey":   "78e807c4-a1c0-458d-ace5-c465e16f3efb",
    "logger":   {
        "level":    "DEBUG"
    "auto_bind":    [{
            "name": "PiThing",
            "gateway":  false
    "certificates": {
        "validate": false,
        "allow_self_signed":    true
    "ws_connection":    {
        "encryption":   "none",
        "verbose":  true,
        "msg_timeout":  1000
When I access my TW composer "ws_servers" on "192.168.15.166:8080/Thingworx", I login with an user and a password, Do I have to put these credentials somewhere in the config.json file? This could be the cause why the binding is not possible or has nothing to do?
Thanks!
1 ACCEPTED SOLUTION
alex.augot
(To:OscarD)
Hi Oscar,
I think the issue is you have an incorrect 'Resource' value in config.json.  You're pointing to 'Thingworx' rather than '/Thingworx/WS' which is the endpoint for a websocket connection.  The platform is correctly returning 400 (Bad Request) since it doesn't understand the request the EMS is sending it.  Take a look at config.json.complete in your EMS's etc directory for examples of default values.
4 REPLIES 4
OscarD
1-Newbie
(To:OscarD)
Hi team, any ideas about this issue?
The http_server refers to the server that the EMS starts running so that other processes like the Lua script resource can connect to it.  If you are connecting to a ThingWorx foundation instance using port 8080 then you must pick a different port for the EMS server and enter that port number in http_server. It does not matter what port you pick, however if you use Lua Script Resource you must configure it to use the same port
Here is a good explanation
Using the Edge MicroServer and LSR in a Gateway Scenario
alex.augot
(To:OscarD)
Hi Oscar,
Hi Alex
Thank you for your answer, it solved the issue .
