Error creating trial
HG
8-Gravel
8-Gravel
Hallo,
I have an issue creating a server for the 30-day Evaluation.
By pressing the button "create server" an error "Error creating trial" occurs and no server is created.
Any ideas how to solve this problem?
Thank you very much!
1 ACCEPTED SOLUTION
slangley
23-Emerald II
(To:slangley)
Hi @HG.
When did you try to create your trial?  I was advised there was a problem last week that was resolved, but if you're still having an issue, we will need to look further.  Perhaps, you can try again.
Regards.
--Sharon
slangley
23-Emerald II
(To:HG)
Hi @HG.
I have reached out to the team that supports these instances, and will post an update here once more information is known.
Regards.
--Sharon
slangley
23-Emerald II
(To:slangley)
Hi @HG.
Regards.
--Sharon
HG
8-Gravel
8-Gravel
(To:slangley)
Hi @slangley,
thank you very much for your support! I tried earlier today, yesterday and the day before yesterday - always with the same error notification.
Shortly after your response it finally works and trial is created without error - although I haven't changes a thing. It seems like the problem was solved somewhere in the system.
Anyway, now everything is fine and again thanks for your support, @slangley .
Best regards
