Error importing entities from "Introduction to Thingworx 8" course into ThingWorx 8.2.5-b260
csantos
I have a local instalation of Thingworx (version 8.2.5-b260).
When I try to import a xml entities file into Thingworx I get the error "Error importing: error, Not Acceptable". In my application logs I get the error "Internal error: java.lang.Exception: Conversion Error on Field password : Unable To Convert From com.sun.org.apache.xerces.internal.dom.DeferredElementNSImpl to PASSWORD".
Can someone help me please?
Thank you
supandey
(To:csantos)
Hi @csantos could you try the following :
1. Re export the entities in binary format i.e. using .twx
2. Import this newly exported entities in your ThingWorx 8.2.5 version.
Hope this helps.
csantos
(To:supandey)
Hope this helps.
Hi @supandey,
My problem is on import, how can I export these entities if I cannot import them? The entities that I am trying to import are, as said in the title, from the "Introduction to Thingworx 8" course available at http://precisionlms.ptc.com.
Can anyone help?
Thank You
