Error importing: error, Not Acceptable
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
I'm trying to import an entity (Entities.xml) from one machine to another and getting below errors.
1. Internal error: com.sun.org.apache.xerces.internal.impl.io.MalformedByteSequenceException: Invalid byte 1 of 1-byte UTF-8 sequence.
2. [message: [1,013] Data store invalid session error: [Error occurred while accessing the model provider.]]
Note: both the machines has same configuration and TWX version.
What could be the reason of it?
- Labels:
Troubleshooting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Tarun, does the import works in different machine, i.e. the machine from where you have exported this current entity? If you have a tool something like Notepad++ you can open this entity.xml and check if it really is UTF-8, it shows up somewhere down right bottom in notepad++
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Sushant,
one is Dev machine and another is Test machine with same TWX instance. I took export from DEV and tried to import into Test but failed.
And yes exported file has encoding as UTF-8.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Could you please add the screenshot of the status bar of Notepad++ where you have this file opened just just to confirm that Notepad++ also sees the encoding as UTF-8 (as mentioned in the screenshot i have shared above)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Tarun,
Try the resolution given in this article.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Janet,
Code was already UTF-8 and I have already tried this but no luck
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Tarun,
Could you provide a screenshot of your Java tab in Tomcat Configuration ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I can't provide Tomcat configure window screenshot.
"Catalina.sh" is fine?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Didn't setup tomcat using exe file. I can provide you Conf files,if you want.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Yes , please attach your Catalina.sh .
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Tomcat configuration recommendations
If you are using Windows operating system , read the above link to create a setenv.bat file and place it in the Tomcat bin directory.The setenv.bat is run by catalina.bat. Now add the below line in the file setenv.bat
set "JAVA_OPTS=%JAVA_OPTS% -Dfile.encoding=UTF8"
If you are using linux , then do the same in setenv.sh.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I think its good hint from Janet, also a 2nd look at the screenshot shows that you are working on Macintosh environment and the encoding is UTF w/o BOM and not just UTF-8 i am still not 100% if this is an issue but you could check this thread for the difference https://stackoverflow.com/questions/2223882/whats-different-between-utf-8-and-utf-8-without-bom
