I'm trying to import an entity (Entities.xml) from one machine to another and getting below errors.
1. Internal error: com.sun.org.apache.xerces.internal.impl.io.MalformedByteSequenceException: Invalid byte 1 of 1-byte UTF-8 sequence.
2. [message: [1,013] Data store invalid session error: [Error occurred while accessing the model provider.]]
Note: both the machines has same configuration and TWX version.
What could be the reason of it?
Hi Tarun, does the import works in different machine, i.e. the machine from where you have exported this current entity? If you have a tool something like Notepad++ you can open this entity.xml and check if it really is UTF-8, it shows up somewhere down right bottom in notepad++
Hi Sushant,
one is Dev machine and another is Test machine with same TWX instance. I took export from DEV and tried to import into Test but failed.
And yes exported file has encoding as UTF-8.
Could you please add the screenshot of the status bar of Notepad++ where you have this file opened just just to confirm that Notepad++ also sees the encoding as UTF-8 (as mentioned in the screenshot i have shared above)
Hi Tarun,
Try the resolution given in this article.
Hi Janet,
Code was already UTF-8 and I have already tried this but no luck
Hi Tarun,
Could you provide a screenshot of your Java tab in Tomcat Configuration ?
I can't provide Tomcat configure window screenshot.
"Catalina.sh" is fine?
Didn't setup tomcat using exe file. I can provide you Conf files,if you want.
Yes , please attach your Catalina.sh .
Tomcat configuration recommendations
If you are using Windows operating system , read the above link to create a setenv.bat file and place it in the Tomcat bin directory.The setenv.bat is run by catalina.bat. Now add the below line in the file setenv.bat
set "JAVA_OPTS=%JAVA_OPTS% -Dfile.encoding=UTF8"
If you are using linux , then do the same in setenv.sh.
I think its good hint from Janet, also a 2nd look at the screenshot shows that you are working on Macintosh environment and the encoding is UTF w/o BOM and not just UTF-8 i am still not 100% if this is an issue but you could check this thread for the difference https://stackoverflow.com/questions/2223882/whats-different-between-utf-8-and-utf-8-without-bom
