Using the example config.json from https://developer.thingworx.com/resources/guides/thingworx-raspberry-pi-quickstart/configure-ems with my hosted instance and generated appKey I get the following error when executing "sudo ./wsems"
[FORCE] 2018-03-26 14:34:17,302 ./wsems: Initializing EMS ....
[FORCE] 2018-03-26 14:34:17,302 main: Using config file /home/pi/thingworx/microserver/etc/config.json
[INFO ] 2018-03-26 14:34:17,302 ./wsems: Creating the WsEms proxy.
[INFO ] 2018-03-26 14:34:17,302 ./wsems: Starting HTTP Server.
[INFO ] 2018-03-26 14:34:17,302 Main: Using custom certificate and private key for HTTP Server
[ERROR] 2018-03-26 14:34:17,303 Main: Failed to get HTTP Server ssl configuration.
[FORCE] 2018-03-26 14:34:17,303 Main: Exiting....
[DEBUG] 2018-03-26 14:34:17,303 jsonConfigurator::~jsonConfigurator: Deleting JSON object
Try with this:
"ws_servers": [{
"host": "pp-1802071422as.devportal.ptc.io",
"port": 443
"http_server": {
"host": "127.0.0.1",
"port": 8080,
"ssl": false,
"authenticate": false
"appKey": "990d0f05-c17f-4416-aa07-beefd1e61b50",
"logger": {
"level": "DEBUG"
"auto_bind": [{
"name": "PiThing",
"gateway": false
"certificates": {
"validate": false,
"allow_self_signed":true
"ws_connection": {
"encryption": "ssl",
"verbose": true,
"msg_timeout": 1000
Seems to be issue with HTTP Server Configuration in config.json file.
Could you please provide me the config.json file so that i can review at my end and see if there is something incorrect in the file?
Himesh Rajpal
as I said it's the sample config:
"ws_servers": [{
"port": 443
"http_server": {
"port": 8080
"logger": {
"level": "DEBUG"
"auto_bind": [{
"name": "PiThing",
"gateway": false
"certificates": {
"validate": false,
"ws_connection": {
"verbose": true,
"msg_timeout": 1000
Try with this:
"ws_servers": [{
"port": 443
"http_server": {
"port": 8080,
"ssl": false,
"logger": {
"level": "DEBUG"
"auto_bind": [{
"name": "PiThing",
"gateway": false
"certificates": {
"validate": false,
"ws_connection": {
"verbose": true,
"msg_timeout": 1000
It is working for me, Thanks!
i tried it but its not working in my case
Could you please share your config.json file?
Gopal
Hi @eifinger
Just wanted to follow up to see if your question has been answered. If so, please indicate Accepted Solution for the benefit of all of our Community users. If not, please let us know your current status.
Thanks!
Leigh
