I am getting the below error continuously in application log. I am using thingworx version 7.1.2-b50.
Error occurred while validating HTTP header: cookie
We are getting serious performance issues in production. Is this error causing the problem.
Raju, the error you're getting is related to the browser cookie not validating correctly on our regex. The validation.properties (under ThingworxStorage/esapi) has a section called 'Validator.HTTPHeaderValue_cookie' where you can add extra characters to allow them through.
With that being said, it should not cause any performance issues per se, as this only affects logging.
I got it. So can we do anything that improves the performance.
Hi @Aanjan,
I have updated the property "Validator.HTTPCookieValue=^[a-zA-Z0-9-\\\/+=_%;\.| ]*$" and my cookie id was "JSESSIONID=5D443A9AACEABC3C44B7C4883B142D26". The Id seems to match the regex i had checked, but i can still see "Error occurred while validating HTTP header: cookie" in the logs.
Based on this article, i had changed the platform.settings file as below,
{ "PlatformSettingsConfig": { "BasicSettings": { "HTTPRequestHeaderMaxLength": 10000, "HTTPRequestParameterMaxLength": 10000 } }, "PersistenceProviderPackageConfigs": { "PostgresPersistenceProviderPackage": { "ConnectionInformation": { "jdbcUrl": <jdbc:postgresql://postgresql URL/thingworx>, "password": "password", "username": "twadmin", "maxPoolSize": "15000", "minPoolSize": "500" } } } }
But the issue persists. Please advice.
Thanks and Regards
Saran
We are also seeing a huge amount of these in our ApplicationLog.log
Error occurred while validating HTTP header: variousHeadersListedHere
I'm looking to eliminate these, to make it easier to locate ACTUAL erros in the logs. ...not as much concerned about logging-performance.
