Error occurred while validating HTTP header: cookie
rk-31
7-Bedrock
I am getting the below error continuously in application log. I am using thingworx version 7.1.2-b50.
We are getting serious performance issues in production. Is this error causing the problem.
Pai Chung
Aanjan Ravi
Aanjan
(To:rk-31)
Raju, the error you're getting is related to the browser cookie not validating correctly on our regex. The validation.properties (under ThingworxStorage/esapi) has a section called 'Validator.HTTPHeaderValue_cookie' where you can add extra characters to allow them through.
With that being said, it should not cause any performance issues per se, as this only affects logging.
4 REPLIES 4
Aanjan
(To:rk-31)
rk-31
7-Bedrock
(To:Aanjan)
I got it. So can we do anything that improves the performance.
Hi @Aanjan,
I have updated the property "Validator.HTTPCookieValue=^[a-zA-Z0-9-\\\/+=_%;\.| ]*$" and my cookie id was "JSESSIONID=5D443A9AACEABC3C44B7C4883B142D26". The Id seems to match the regex i had checked, but i can still see "Error occurred while validating HTTP header: cookie" in the logs.
Based on  this article, i had changed the platform.settings file as below,
"PlatformSettingsConfig": {
		"BasicSettings": {
			"HTTPRequestHeaderMaxLength": 10000,
			"HTTPRequestParameterMaxLength": 10000
	"PersistenceProviderPackageConfigs": {
		"PostgresPersistenceProviderPackage": {
			"ConnectionInformation": {
				"jdbcUrl": <jdbc:postgresql://postgresql URL/thingworx>,
				"password": "password",
				"username": "twadmin",
				"maxPoolSize": "15000",
				"minPoolSize": "500"
But the issue persists. Please advice.
Thanks and Regards
Saran
We are also seeing a huge amount of these in our ApplicationLog.log
Error occurred while validating HTTP header: variousHeadersListedHere
I'm looking to eliminate these, to make it easier to locate ACTUAL erros in the logs.  ...not as much concerned about logging-performance.
