i tried to access this url http://localhost:5555/Devices/
to get json response data but I am getting below error
Error executing service Message :: Connect to localhost:5555 [localhost/127.0.0.1] failed: Connection refused (Connection refused) - See Script Error Log for more details.
but i can access this url with Postman and get response
service:
thanks in advance
Hi @Nour4.
Are you passing some credentials in the Postman call that you're not able to pass when accessing the url directly? Is it possible that you have a firewall rule at the app level that is allowing Postman to succeed?
--Sharon
