Errror in PostgresqlDBsetup
Peter_Raj
11-Garnet
Hi
I have installed Postgresql in my local pc and i  am getting the following error in ThingworxPostgresqlDBsetup.bat file and thingworxPostgresSchemaSetup.bat file
Can anyone guide me to rectify this error
5 REPLIES 5
1. Delete any tablespace created in the location ThingworxBackupStorage; check also in Postgres database to NOT have any datbase called "thingworx" or tabespace called "thingworx"; if any just delete them from database.
2. Run ThingworxPostgresqlDBsetup.bat  with tablespace location  C:/<path_to_location> or C://<path_to_location>
3. After successful ThingworxPostgresqlDBsetup.bat, run also thingworxPostgresSchemaSetup.bat
Best regards,
Raluca Edu
I followed your steps but I dont find Thingworx on any of the database and Tablespaces
but still the error apears again
Are you executing the script from the path where the script resides?
If not, I recommend to change directory to that path and execute the script again. Also, you need to have psql in environment vars.
Best regards,
Raluca Edu
The same error comes again
Please change tablespace location, open script in edit mode and add the path where you want your tablsespace to be created.
Then run again script.
Best regards,
Raluca Edu
