Export a mashup to PDF file
quangnguyenduc4
7-Bedrock
I've currently have a task on exporting a mashup to a PDF file. I downloaded pdf extension from this link
https://community.ptc.com/t5/ThingWorx-Developers/Where-can-I-download-PDF-Extension-for-ThingWorx/td-p/632980 . And configured :
AppKey:,
ServerAddress:http://localhost:5000/Thingworx/Runtime/index.html#mashup=DRK_mhp_CustomerManagement,
OutputFileName: Report.pdf,
FileRepository: SystemRepository
But it didn't work. Can anyone help me is configuration wrong or I have to download latest PDF extension(can u give me download link).
Hi @quangnguyenduc4.
Because the extension provided in the post you linked to is not provided by PTC, we have no knowledge of how it works.  PTC does not currently provide a PDF extension even though we have in the past.  It's recommended that you submit a request through the ThingWorx Ideas board with details of your requirements.  This will allow others to vote for it which will increase the possibility that it will be considered for a future release of ThingWorx.
The alternative is to write your own extension.  You can refer to these sources for help:
Packaging and Deploying Applications Built on the ThingWorx Platform
Create A Mashup Widget Extension
--Sharon
--Sharon
If the previous response answered your question (even if it wasn't the response you were hoping for), please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
