Extension development - database thing template
KG_9261951
Hello all,
I'm trying to create thing template based on database thing template in my custom extension. Using creator I've created thing template named MSSQLThingTemplate which is extending database thing template:
@ThingworxBaseTemplateDefinition(name = "Database")
public class MSSQLThingTemplate extends Thing {
	public MSSQLThingTemplate() {
		// TODO Auto-generated constructor stub
The problem is that after creating thing template using this method i'm not able to add SQL Query or Command service to thing created from MSSQLThingTemplate, only Local (JavaScript) is visible. Do you know how to fix this? Should this thing template extend different class? Thanks in advance for help.
No, but if you're aiming to create a JDBC connector that allows you to access a database, there's another process that does not involve going into Java to do that (it's much more simpler).
It is available here: http://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/#page/ThingWorx%2FHelp%2FExtensibility%2Fjdbc_extension.html
Would you be interested in that, or do you really need to process some code in Java and this is why you went the Java extension route?
slangley
(To:KG_9261951)
Hi @KG_9261951.
If the previous response allowed you to find a solution, please mark it as the Accepted Solution for the benefit of others with the same issue.
Thank you for your participation in our community!
--Sharon
slangley
(To:KG_9261951)
Hi @KG_9261951.
I have marked the Accepted Solution for this post.  If you disagree that it is the solution, please let me know.
--Sharon
