Extension is not importing in one server but successfully imports in another server
AP_10343008
I am getting these two Errors while importing print extension in localserver. But same extension got imported in other servers..
Extension Exception: java.io.FileNotFoundException: C:\PROGRA~2\THINGW~1\ThingworxStorage\extensions\temp\OpenPrintButton_fb423bfc-0460-43e2-b53c-0503b46e52ae\OpenPrintButton\ui\OpenPrintButton\images\button-disabled.png (Access is denied)
C:\Program Files (x86)\ThingWorxFoundation\tomcat\current\webapps\Thingworx\Common\extensions\chartWidget_ExtensionPackage\ui\lineChart\lineChart.ide.js (The system cannot find the file specified)
3 REPLIES 3
slangley
23-Emerald II
(To:AP_10343008)
Hi @AP_10343008.
I see that you're getting an Access denied error.  Did you try the import under the Administrator account?
--Sharon
AP_10343008
(To:slangley)
From Administrator username also same error is coming.
slangley
23-Emerald II
(To:AP_10343008)
Hi @AP_10343008.
Make sure the account configured to run the Tomcat service has full access to ThingworxStorage and all sub-folders.  Also, validate there are no space issues on the server.
Is everything configured the same in the 2 environments--same o/s version, same ThingWorx version, etc.?
--Sharon
