Extension with API
asaito-3
3-Visitor
Extension with API
Hi All,
I am trying to use a JSON result from an API call in a grid...but for this, I need to convert the JSON data to INFOTABLE data type.
The question is
: how?
I am creating two services for this, but I don't have a clue if this is the best way to go...
A service that give the JSON from the API call, and another one, that will convert the JSON from the previous one.
Any tips?
Anselmo.
1 ACCEPTED SOLUTION
rnayak-2
(To:asaito-3)
The error seems to be for typecasting ....whats your output basetype ? make sure it is of base type 'infotable'.
6 REPLIES 6
mgoel
(To:asaito-3)
Hi Anselmo Saito
Could you please try the below article for the solution:
https://www.ptc.com/en/support/article?n=CS179012
Do let me know in case of any question.
Mohit Goel
asaito-3
3-Visitor
(To:mgoel)
It says that I have no Infotable created...but this is exactly what I want to do with some kind of conversor...
Here is my code following what is in this link:
var text = '{ "employees" : [' +
'{ "firstName":"John" , "lastName":"Doe" },' +
'{ "firstName":"Anna" , "lastName":"Smith" },' +
'{ "firstName":"Peter" , "lastName":"Jones" } ]}';
var json = JSON.parse(text);
var params = {
infoTableName : "employees",
dataShapeName : "AlertEvent"
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(AlertEvent)
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
for(var i=0;i<json.length;i++){
    Infotable.AddRow({Name:json.firstName, Value:json.lastName});
result = InfoTable;
rnayak-2
(To:asaito-3)
In your for loop you have incorrectly specified as " Infotable.AddRow" which should be actually " result.AddRow". Once you do that you dont need the last line "result = InfoTable" as you are directly adding info from json to your result set. Do this change and run the code again and see if it gives you what you need !
After these changes I received a diferent error message :
com.thingworx.dsl.engine.adapters.ThingworxInfoTableAdapter cannot be cast to com.thingworx.types.InfoTable
rnayak-2
(To:asaito-3)
That's it. Thanks!
