Facing an error while importing build to Thingworx: some jar files are missing
hbavirisetti
Hello guys,
I am following Create Extensions w/ Eclipse Tutorial from Thingworx Dashboard to create a weather mashup using Eclipse code. I have created the build using Gradle STE and importing the build to Thingworx, while validating the build it showing like some jar files are missing. But I am not finding any missing jar files. Can anyone help me to resolve the issue ?
Hemanth kumar
8 REPLIES 8
Hi Hemant,
Is their any jar file that you imported in your project which is not part of the ThingWorx extension SDK?
Ankit Gupta
Also, check for more errors in Application logs.
Hi Ankit Gupta,
I am not finding any errors in Thingworx Application Logs.
Hemanth kumar
Hi Ankit Gupta,
I have added json-simple-1.1.1.jar, httpclient-4.5.2.jar, httpcore-4.4.5.jar and commons-logging-1.2.jar files in the project. In the tutorial add httpclient-4.5.2.jar file but the EclipsePlugin.zip provided by Thingworx existed with httpclient-4.5.1.jar.
Is this face any issue ?
Hemanth kumar
Can you please open the extension zip to see if these external jars are included in the zip?
Hi Ankit Gupta,
Thanks for your reply. I have extracted the zip file. Below are the jar files existed in the lib folder.
Hemanth kumar
Hemant, This seems correct. Is the SDK version same as ThingWorx version?
Please share your extension here so that I can try to test it on my local instance.
If the extension is private; you can can share it via email or one to one Community message.
Hi Ankit Gupta,
Thanks for your good response on my issue.
Yes I am using the Thingworx development 30 days trail version of 7.2.1 - b71. The SDK I am using is 7.2.0 version.
But I have installed Thingworx 7.1.1 in my machine but I didn't find any related SDK, Eclipse Plugin for Thingworx Extension.
Hemanth kumar
