Fail to restart with h2 -- ubuntu tw 8.4
memelet
With a fresh install using the textual installer using all defaults.
if I run
$ catalina.sh stop
$ catalina.sh start
I get the error:
*** CRITICAL ERROR ON STARTUP: Improper value found for model provider configuration password, system cannot start without valid password
*** Web Application STATE is being set to ERROR! ***
If I destroy the VM and reinstall, foundation runs fine after the install. But any attempt to restart will not start.
The config for h2 (created by the installer) contains
"PersistenceProviderPackageConfigs": {
                "H2PersistenceProviderPackage": {
                        "ConnectionInformation": {
                                "password": "\u003caddsecurepassword\u003e",
                                "username": "twadmin"
(This is after finishing up the install of the analytics server, so it would really suck to have to start all over again)
memelet
(To:memelet)
Sorry, had a syntax error in the json unrelated to the h2 password. The exception indicated this further up on the log. The message threw me off.
memelet
(To:memelet)
