We are troubleshooting an issue impacting community login, and it may be intermittently unavailable. Sorry for any inconvenience.
Hi team,
suddenly Thingworx stopped running getting below error.
Failed to load FlxCore library. Ensure it's in PATH (Windows) or LD_LIBRARY_PATH(other platforms) or set with the VM arg, -Djava.library.path. Error message : com.flexnet.licensing.DllEntryPoint.entry([B)I
even we set the setenv.sh to CATALINA_OPTS="$CATALINA_OPTS -Djava.library.path=/usr/share/tomcat8.5/8.5.13/webapps/Thingworx/WEB-INF/extensions"
please get back soon.
@mkumar2 This seems related to the other existing thread -
Please provide details as requested and advise on the latest error you are getting.
-Durgesh
@mkumar2: I believe your entry in setenv.sh is not correct and should be something like as below -
export JAVA_OPTS="-Djava.library.path=/usr/share/tomcat8.5/8.5.13/webapps/Thingworx/WEB-INF/extensions"
-Durgesh
Seems that you have a 32 bit version of Tomcat (note how the path is x86). Please uninstall your tomcat, download a 64 bit version, and install from there.
https://www.inthow.com/ https://firedout.com/ https://techfela.com/ https://techimpose.com/ https://distantinfo.com/ https://2into.com/
Hi @mkumar2.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
