Fetch user's avatar
srude
1-Newbie
Fetch user's avatar
I am creating Service for obtaining user's avatar:
var currentUser = Resources["CurrentSessionInfo"].GetCurrentUser();
var result = Users[currentUser].getAvatarURL();
But I am getting 500th server error code. Could you please point me out my mistake and help me fix my code.
I asked my question also on https://stackoverflow.com/questions/36771705/thingworx-fetch-users-avatar
Thanks in advance! I appreciate your help!
1 ACCEPTED SOLUTION
Aanjan
9-Granite
(To:srude)
Serg, sorry, I had misread your question. This does work for me -
var result = Users[currentUser].GetAvatarURL();
currentUser stores Administrator, and I've set output of the service to STRING and I get the following as my result -
/Thingworx/Users/Administrator/Avatar
5 REPLIES 5
Aanjan
9-Granite
(To:srude)
Serg, if you're fetching the current user's avatar, you can use
var result = me.GetAvatarURL();
srude
1-Newbie
(To:Aanjan)
Aanjan, first of all thank you for your attention.
I want avatar be dynamically return depends on who logged in.
So I decided create HelperThing and implemented service above in this  HelperThing, if  I call me.GetAvatarURL(); - it will return me Avatar of HelperThing.
Aanjan
9-Granite
(To:srude)
srude
1-Newbie
(To:Aanjan)
Aanjan, sounds good. Seems if narrow down the problem. I would like to return IMAGELINK. Could you, please, show me the casting.
Aanjan
9-Granite
(To:srude)
Serg, you can use the same code from above, and set the service output to IMAGELINK instead of STRING. You would get the image/ icon of that user.
