I'm working on a project that requires the fetching of pvz from thingworx flow. I used the following actions to do so: get structure to fetch BOM, a loop to iterate on each element of the array fetched with the aformentioned action and a get content to fetch pvz. The issue is that the fetched pvz are almost empty. Is there another way to fetch pvz?
Thanks in advance
Hi @FC_12202090.
Take a look at this article. If it doesn't help, please provide more details of your configuration.
Regards.
--Sharon
Similar discussion - "PVZ for positioning assembly": https://community.ptc.com/t5/ThingWorx-Developers/PVZ-for-positioning-assembly/td-p/778825
Hi @FC_12202090.
Regards.
--Sharon
Hi @slangley , I will try to apply what said in this article and let you know if there are any issues.
Hi @FC_12202090
If you feel your question has been answered, please mark the appropriate response as the Accepted solution for the benefit of others with the same question. If you still have questions, please let us know.
Regards.
--Sharon
