Good day Team,
I am curious if ThingWorx has any extension in order to get the factory model from FiiX software. Or another way around?
Thank you!
I do not know of any extension, but I believe they may have a REST API so you can create an interaction that way.
Hi @oparfon.
If the previous response helped you to find a solution, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
