File transfer from server thing to remote thing in agent is not working
rkandasamy
I am transferring a zip file from server to remotethingwithfiletransfer in agent(EdgeSDK .net code ). But i the file is not copied to agent's virtual directory and i am getting  the below error "The given key was not present in the dictionary." in the result of calling copy service in thingworx server. Let me know if you could help me in resolving the same.
Thanks.
Check read/write permissions of your Repositories. It should be creating some sort of Temp subfolder I believe, might be failing that.
kk-2
(To:paic)
Hi Now we are getting different error. The file is transferred from server repository to SDK solutions virtual directory. The file is transferred but in the result infotable of copy service
  1. Code is 500 instead of 200
  2. State is ERROR instead of VALIDATED
  3. Message is Unable To Convert From InfoTable to INFOTABLE instead of file transfer complete
  4. isComplete is flase instead of true.
We had tried the same code with two different sdks. The code provided below is put into the service of a thing in server.
var params = {
                async: false /* BOOLEAN */,
                sourceRepo: "Tierra" /* STRING */,
                targetRepo: "Prescription" /* STRING */,
                targetFile: FileName /* STRING */,
                targetPath: "In" /* STRING */,
                sourceFile: FileName /* STRING */,
                sourcePath: "/" /* STRING */,
                timeout: 150000 /* INTEGER */
ServerDirectory is a thing based on FileRepository. SDKCommonThing is a thing on the Dot net EDGE SDK side. We are not sure what causes Unable To Convert From InfoTable to INFOTABLE.
Let me know if you could provide any input on the same.
Given Result Table Below:
targetChecksum
code
isAsync
maxSize
sourceFile
startPosition
duration
isRestartEnabled
targetFile
startTime
state
sourcePath
blockCount
sourceRepository
bytesTransferred
targetPath
sourceChecksum
message
transferId
blockSize
size
endTime
targetRepository
user
isComplete
3fa8a947d6ce15fa97e1bd7cf860112f
500
false
100000000
Prescription001.zip
0
835
true
Prescription001.zip
2015-09-22 12:03:43
ERROR
/Outgoing/Prescription001.zip
12
Tierra
771137
In/Incoming/Prescription001.zip
d3f0a7e5-3724-43cd-9954-b42c958e663e
65536
771137
2015-09-22 12:03:44
Prescription
Administrator
false
paic
(To:kk-2)
If this is the standard messages that the File transfer should be generating, then it looks like it may be a bug. Please submit this at support.ptc.com
