File upload widget is not showing on mashup.
Suraj2692
I am using Thingworx 8.5 version, when i used file upload widget on mashup it will show for 3 to 4 days but when i am opening same mashup after 5 to 6 days it will not showing file upload on this mashup.
I have created one another mashup which i again insert file upload widget and view mashup then same problem i am facing still it is not showing file upload widget on mashup.
Now on every mashup file upload widget is not showing.
Is i'm wrong please suggest whats wrong in that.
Thanks in advance
PaiChung
22-Sapphire I
(To:Suraj2692)
I think there might be a weird bug here, try changing a configuration on the Widget properties, then save the mashup and run it again.
You can always change the configuration back afterwards.
