Font Labeling - Upload custom fonts
Sathishkumar_C
I am using Font labeling Widget but i can't able to upload ttf fonts using Media entity. Is there any solution?
Thingworx Version 8.0
Sathishkumar C.
Please note that the extension provided in the Marketplace is in "as-is" condition and is not currently supported
This item has been tested and certified by ThingWorx to successfully work with the ThingWorx platform, however this item is not currently supported by ThingWorx. By utilizing this item you acknowledge that the content is provided in ‘as-is’ condition and support will not be provided
7 REPLIES 7
I am having this same issue in ThingWorx 8.  I got the Font Label extension installed, but when I attempt to import a .ttf file into the media entity, I get an error thrown on the application log:  Internal error: java.lang.IllegalArgumentException: image == null!
I understand that the widget is not supported any more but I now have to completely recreate large chunks of mashups that used this widget in 7.3.  Are there any workarounds or fixes that anybody has run into?
Thanks.
posipova
20-Turquoise
(To:nmilleson)
Bob Neubaum​ anything you guys could assist with?
I am also interested in this feature. Nick Milleson​, did you come up with a workaround?
Hi mundel,
Now Font Labeling Widget is working fine. Try to download from ThingWorx IoT Marketplace and Use.
Thanks & Regards,
Sathishkumar C
Hi Sathishkumar,
Yes it working but  unfortunately you are not able to upload any new font as media entity !!!
Could you try to upload a new font to media entity?
The problem is existing from version 7.4 ....
My Best...
pjoly
(To:DVMTech)
same issue
I cannot upload a ttf file as media to use the font
any progress ?
