FormLogin - access problem. Redirect failed.
SOLVED
Re: FormLogin - access problem. Redirect failed.
Thank you Polina Osipova​, I guess I'll have to delete everything and start fresh (it is a test platform anyway)
Please ensure to install a supported version of postgresql. It's strange that your application even started with a 9.6. :-)
What's more strange is that it did work with 7.3 for quite some time =) however, I didn't try the FormLogin function
Hi mnudel,
Is this issue resolved at your end? Let us know what are the steps you did for the same. We are also facing the same issue
when upgrading TW from Version 7.1 to 7.4 and the version of Postgres we are using is 9.4 only. We are using a Linux 64 bit system with
tomcat 8.0.36 version.
Hello Rdhakrishnan Kandasamy​,
As Polina Osipova​​​ indicated, I was using more recent version of PostgreSQL. I'm hoping to resolve this by reinstalling everything using recommendations above.
It could be not related to the version of the database, but something more specific as Sushant Pandey​ described.
May be it's bit too early to say but it could be an issue, there's already a Jira PSPT-3573 on redirect issues for Manage Extensions (which BTW do log this intrusion detection stuff in application log) mashup not addressable from Composer and also related to Organization Form Logins not able to redirect. Though i'm not 100% if this is what you are also running into.
None of this is reproducible when doing fresh installation of v7.4.
Hi Rdhakrishnan Kandasamy , thank you for sharing the details over webex I have those details added to the article for reference. Note that the Jira is still open so will let you know as soon as this is fixed.
