Formulas in streams?
apineda
I was wondering if ThingWorx supports an automated column defined by a formula akin to adding formulas to columns in Excel tables.
I have data in raw forms such as voltage but I would like to convert these values to something more meaningful like temperature, barometric pressure, flow rate, etc.
Thanks!
byutz
(To:apineda)
Hi Alister,
I have not seen a way to put a formula in a stream directly, but you could write a service to do a calculation everytime a stream entry is made.  You could have the service add a column and make your calculation.
apineda
(To:byutz)
That's basically what I have done so far. It would be nice to have something more dynamic in case the expression changes for whatever reason.
The other way around, it's to make a service which executes the stored or in service formula, and returns the new columns, attached to current stream entries, you just need to AddField and/or use Derived functions.
Carles.
