dear all
Generate any file type or Reports, how to store from System Repository .
I would suggest using what @Sathishkumar_C said.
There are no supported ways of creating PDF or excel files on thingworx from what I can understand.
You can create a CSV file however using the CSVParserFunctions:
let params = {
path: undefined /* STRING */,
data: undefined /* INFOTABLE */,
fileRepository: undefined /* THINGNAME */,
withHeader: undefined /* BOOLEAN */
// no return
Resources["CSVParserFunctions"].WriteCSVFile(params);
Give it a shot and get back to us if you any further questions.
Jens
I'm not sure I understand your question?
Would you just like to store any file type in a system repository?
Or would you like to actually create any file type on thingworx?
Jens
for example database(sql) in some table through convert report file .csv or excel store to System repository
let params = {
// no return
Jens
i would like to .csv ,pdf, excel separate file in and separate user
