Connection Between KepServerEX and Softing 56eATM-OPC UA Server with CA validated certificates
  • November 25, 2022
  • 2170 views
  I'm trying to connected KepServerEX v6.8 with a Softing 56eATM-OPC UA Server with CA validated Certificates and when I'm doing the connection I recive this message:
  Channel failed to connect. | Status description = 'The user identity token is not válid.' Status code = 0X80200000.
  The only text that I found at support it's to desable security login, but it's not an option for me.
Best answer by slangley
Hi @Grimpow.
For the greater community......as you discovered, the functionality does not currently exist for configuring a user certificate in KepServer.
If you have additional information you would like to share, please feel free to do so.
Regards.
--Sharon
Article - "'The user identity token is not valid.', Status code = 0X80200000 error is posted in KEPServerEX / ThingWorx Industrial Connectivity": https://www.ptc.com/en/support/article/CS291994
Grimpow5-Regular MemberAuthor
  The problem it's that I can't acept anonymous login. I need Certification Authority validated certificates
Community Manager
December 13, 2022
Hi @Grimpow.
If you have a support account, it might be best to open a case.  If you agree, please private message me your PTC support email address and I will be happy to create the case on your behalf.
Regards.
--Sharon
