Generate file or reports
Hariharasuthan
dear all
Generate any file type  or Reports, how to store from System Repository .
I would suggest using what @Sathishkumar_C said.
There are no supported ways of creating PDF or excel files on thingworx from what I can understand.
You can create a CSV file however using the CSVParserFunctions:
let params = {
	path: undefined /* STRING */,
	data: undefined /* INFOTABLE */,
	fileRepository: undefined /* THINGNAME */,
	withHeader: undefined /* BOOLEAN */
// no return
Resources["CSVParserFunctions"].WriteCSVFile(params);
Give it a shot and get back to us if you any further questions.
Jens
5 REPLIES 5
I'm not sure I understand your question?
Would you just like to store any file type in a system repository?
Or would you like to actually create any file type on thingworx?
Jens
Hariharasuthan
(To:jensc)
for example database(sql) in some table through convert report file .csv or excel  store to System repository
let params = {
// no return
Jens
Hariharasuthan
(To:jensc)
i would like to .csv ,pdf, excel  separate file in and separate user
