My Team have recently upgraded ThingWorx to 8.5 from 8.3.
As a normal user, I am getting the above REST service failure: Unauthorised when I tried to create a new Thing using the Generic Thing Template.
Is this a permission issue?
If so, where and which permission do I need to get the admin to set?
The error in logs is {Not authorized for ServiceInvoke on GetHandlerDefinitions in ConfiguredThing.}
The admin have tried setting permissions for visibilities, run time and design time on the Generic Thing Template but it is not working.
Hi @hujingrui
Starting from ThingWorx 8.4, the security of Thingworx was improved and this means some access rights were changed or revoked. Please follow below steps with the Administrator user:
Vibhuti
Hi @hujingrui
Vibhuti
