Generic Thing Error - REST service failure: Unauthorised
hujingrui
My Team have recently upgraded ThingWorx to 8.5 from 8.3.
As a normal user, I am getting the above REST service failure: Unauthorised when I tried to create a new Thing using the Generic Thing Template.
Is this a permission issue?
If so, where and which permission do I need to get the admin to set?
The error in logs is {Not authorized for ServiceInvoke on GetHandlerDefinitions in ConfiguredThing.}
The admin have tried setting permissions for visibilities, run time and design time on the Generic Thing Template but it is not working.
Hi @hujingrui
Starting from ThingWorx 8.4, the security of Thingworx was improved and this means some access rights were changed or revoked. Please follow below steps with the Administrator user:
  1. Login to Composer
  2. Go to System -> Resources
  3. Click on CollectionFunctions Resource
  4. Execute AddCollectionVisibilityPermission service with below parameters
    • collectionName - ThingPackages
    • principal - <Organization or Organizational Unit Name>
      • Organizational Units are declared as <Organization Name>:<Organizational Unit Name>
    • principalType - Organization / OrganizationalUnit
  • For ThingWorx 8.4 and up the following must also be performed:
    4. Execute AddCollectionRunTimePermission service with below parameters
      • type - ServiceInvoke
      • resource - * (all) / <Specific Property, Service or Event Name>
      • principal - <User or Group Name>
      • principalType - User / Group
      • Allow - True
Vibhuti
Hi @hujingrui
      • Allow - True
Vibhuti
