Is it possible to get the button-ID (and related properties) who started a service from a mashup ?
what I would make easier is this:
I have a service who makes a data-preview, or a data-import . This service is called from a mashup button.
A boolean variable can be set as service parameter to switch between the two functions.
I would have instead 2 buttons on the mashup, one that makes preview, another that makes import.
Is it possible to get button ID from inside the service ? If so, I can switch from preview and import without need to deal with a BOOL to set/reset from the mashup
I know I could do by duplicating the service .. and use one button for each one ... but make mashup mode complex ..
One of the ways to achieve your scenario is by using toggle buttons instead of regular buttons on the Mashup. Please follow the below steps to achieve your use case.
if(Inp1){
Output = "Preview";
else if(Inp2){
Output = "Import";
else{
Output = "No action";
Now bind the output of this expression to the service that does your implementation. Please make sure it accepts String as an input parameter and write the condition accordingly. Please let me know if you run into any issues with the implementation.
if(Inp1){
Output = "Preview";
else if(Inp2){
Output = "Import";
else{
Hi @iguerra.
If one of the previous responses answered your question, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum!
