Getting error ( Error Retrieving Organization) on adding organization to any entity visibility
bgupta-2
Dear Team,
Getting error on adding organization to ant entity visibility. Error Retrieving Organization.
13 REPLIES 13
ankigupta
(To:bgupta-2)
Bhuwaneshwar Gupta
Which ThingWorx version and Tomcat version you are on?
Are you getting any error in logs?
Please check your Tomcat logs too.
supandey
(To:bgupta-2)
Bhuwaneshwar, with what type of user account are you logged in when you see that error? could you please also check the application log for more info on that?
I am using 7.3 version and logged in as Administrator user. No such error on log?
ankigupta
(To:bgupta-2)
Bhuwaneshwar Gupta​,
Could you please share your Tomcat version too?
ankigupta
(To:bgupta-2)
Hi Bhuwaneshwar Gupta
Please refer to the following article; it talks about the same error: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS256326&lang=en_US
Tomcat 8
ankigupta
(To:bgupta-2)
Please share the exact subversion like Tomcat 8.0.33
Tomcat version 8.5  and Thingworx version 7.3.1-b39
Exact tomcat version : 8.5.11
ankigupta
(To:bgupta-2)
Hi Bhuwaneshwar Gupta​,
Tomcat version 8.5.11 is not supported. Try downgrading the Tomcat to version 8.0.33
Refer to following document for ThingWorx 7.4.0 System requirements: http://support.ptc.com/WCMS/files/172625/en/ThingWorx_Core_7.4_System_Requirements_1.0.pdf
