Getting error java.lang.Exception: Unable to initialize and start system: Unable to decode avatar content: Can't create cache file! while Thingworx 8.1 installation
SOLVED
Newbie
I am getting following error while installing Thingworx 8.1.war for postgreSQL on Tomcat 8.0.44 server in my system:
I installed postgreSQL9.4.5 in my system and done all setups for thingworx perfectly like creation of its tablespace, database and tables. Also I provided full read/write access permission on ThingworxPlatform, ThingworxPostgresqlStorage and ThingworxStorage.
I kept licence binary file under ThingworxPlatform folder. As per stated in Thingworx 8.1 installation guide I downloaded this licence file and made entry for LicensingConnectionSettings in platform-settings.json. (Please find all attachments)
Despite of all these setups I am getting above mentioned error.
Can anyone please help me to fix this problem?
Thank you in advance.
Rohit Kumar Jaiswal
1 ACCEPTED SOLUTION
Re: Getting error java.lang.Exception: Unable to initialize and start system: Unable to decode avatar content: Can't create cache file! while Thingworx 8.1 installation
Hi Rohit,
There is error in the application logs :
2017-11-09 17:05:12.437+0100 [L: ERROR] [O: c.t.e.u.UIResourceUtilities] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] C:\Program Files\Apache Software Foundation\Tomcat 8.0\temp\index.html750648625249426041.tmp
Please clear the temp folder and work folder for tomcat and restart the service.
Himesh Rajpal
7 REPLIES 7
Greetings Rohit,
Could you please provide the application logs ?
Himesh Rajpal
Highlighted
Carles Coll and Hi Himesh,
If I am not wrong we are able to get application logs when Thingworx installed in the system and we work on it. Still I unable to deploy Thingworx 8.1.war on Tomcat 8.0.44 server in my Windows system due to mentioned error in last post.
Anyway I am sanding all log files of tomcat server. I think It may help you.
Thank you
Rohit K Jaiswal
Hi Rohit, I have no experience with 8.X for now, I can't help here, hope in the near future we go onto 8.X.
HI Rohit,
You can check the Thingworx Storage folder for the logs . When the tomcat starts to deploy thingworx.war , the logs are generated .
Himesh Rajpal
Prashant Iyer, Hi Himesh,
As requested please find attached ApplicationLog.log of ThingworxStorage logs folder and let me know what I did wrong in this installation. I got stuck due to this.
Thank you in advance for your kind support.
From,
Rohit K. Jaiswal
Hi Rohit,
Himesh Rajpal
Thank you Himesh. It works.
