Google Chart Widget not working since system upgrade
_Lya_1986
Hi All,
I'm Ilona from Hungary.
I've used ThigWorx 8.2.2 for 1 year, and now 3 weks ago the system was updated to 8.4.4 version.
My problem is, earlier i have written some GoogleChart widget swith Extension SDK in Eclipse. It worked well.
But after the upgrade they have been done.
In IDE environment I see the Timeline or another widget, but in runtime it is nowhere.
This is the Timeline code:
https://developers.google.com/chart/interactive/docs/gallery/timeline
I've the loader.js library, it works earlier well. I've written timeline.runtime.js, timeline.ide.js, timeline.ide.css, timeline.runtime.css.
I've used Extension SDK 8.2 and i can't download the newest version.
Error message:
Subscription already exists for this edition. To modify the subscription please select a different edition or change the selected units.
In debug mode I see the sourcecode of Timeline, can make a run line by line, but it seem like not working.
What should be the different between 8.2.2 and 8.4.4 version?
What should I do to solve this problem?
Thank you in advanced,
Ilona
Yes, I'v tried, but the solution has come.
It was a different between the 2 version:
split() function.
In the 8.2 version worked this:
split("SomeString",",")
but in the new version just this working:
SomeString.split(",");
So the code didn't run, but there was no error message, whitch is quite intersting.
THX,
Ilona
2 REPLIES 2
posipova
20-Turquoise
(To:_Lya_1986)
Have you tried with the newer SDK, not 8.2?
https://marketplace.ptc.com/apps/193544/extension-sdk#!overview
The api pattern might have changed, also with the widgets becoming webcomponents.
split() function.
THX,
Ilona
