Hi All,
I get my data from database, and start a new column LOCATION from other two columns, latitude and longitude.
It looks like two digits from longitude and latitude are missing in LOCATION.
I attached the data to the google map widget.
The google map shows nothing. Something is wrong here.
Please advise. Thank you!
Hi Tiantian Guo,
Just to confirm; are you following this youtube tutorial: Thingworx Fundamentals 101 -- How To Use a Google Map Widget - YouTube
Yes. I am following the procedure.
Actually I have done this successfully before. I enter the location manually in the service in javascript. Then the location data can be attached to the google map.
But this time, I obtain the data from the database. The problem happen.
Dear Ankit,
The export of the mashup is:
Hi Tiantian Guo,
I am actually requesting for the xml export of the mashup entity.
Dear Ankit,
Attached is the xml file.
<?xml version="1.0" encoding="UTF-8" standalone="no"?><Entities build="b159" majorVersion="7" minorVersion="4" modelPersistenceProviderPackage="PostgresPersistenceProviderPackage" revision="0" schemaVersion="940"><Mashups><Mashup aspect.isResponsive="true" aspect.mashupType="mashup" columns="0.0" description="" documentationContent="" homeMashup="" lastModifiedDate="2017-05-22T14:33:54.008+08:00" name="Map" projectName="JTC" rows="0.0" tags=""><Owner name="Administrator" type="User"/><avatar><![CDATA[iVBORw0KGgoAAAANSUhEUgAAADAAAAAwCAYAAABXAvmHAAAP/klEQVR42tWaB1hUd7bApwK2kCiW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=]]></avatar><DesignTimePermissions><Create/><Read/><Update/><Delete/><Metadata/></DesignTimePermissions><RunTimePermissions/><VisibilityPermissions><Visibility/></VisibilityPermissions><ConfigurationTables/><ParameterDefinitions/><Things><Thing>ExtractData</Thing></Things><ThingShapes/><ThingTemplates/><mashupContent><![CDATA[{
"RunTimePermissions" : { },
"UI" : {
"Widgets" : [ {
"Widgets" : [ {
"Widgets" : [ {
"Widgets" : [ ],
"Properties" : {
"RouteLocationField" : "location",
"SelectedRegionStyle" : "DefaultMapRegionSelectedStyle",
"Left" : 85,
"LocationField" : "location",
"SelectionMarkerStyle" : "DefaultMapSelectionStyle",
"StartMarkerStyle" : "DefaultMapStartStyle",
"ShowDataLoading" : true,
"ShowPlannedRoute" : false,
"TooltipMashupWidth" : 400,
"MapType" : "roadmap",
"AutoCenterBehavior" : "last-selected",
"ShowMarkers" : true,
"EndMarkerStyle" : "DefaultMapEndStyle",
"RegionMultiSelect" : false,
"SelectedMarkerStyle" : "BuildingmapSelectedStyle",
"TooltipField3" : "severe",
"TooltipField4" : "medium",
"RegionStyle" : "DefaultMapRegionStyle",
"AutoZoomBehavior" : "every-data-change",
"TooltipMashupName" : "",
"TooltipField1" : "name",
"TooltipField2" : "address",
"RouteStyle" : "DefaultMapRouteStyle",
"MarkerFormatting_StateParameters" : [ ],
"RegionFormatting_StateParameters" : [ ],
"EnableLocationSelection" : false,
"Z-index" : 10,
"MashupParameters" : [ ],
"PathStyle" : "DefaultMapPathStyle",
"MarkerStyle" : "BuildingMapMarkerStyle",
"__TypeDisplayName" : "Google Map",
"Area" : "UI",
"Top" : 155,
"Id" : "googlemap-19",
"TooltipMashupHeight" : 300,
"RegionFillOpacity" : 1,
"ShowSelectionMarker" : false,
"MapSkin" : "normal",
"ShowTraffic" : false,
"EnableMarkerSelection" : true,
"RegionLocationsField" : "locations",
"Visible" : true,
"DisplayName" : "googlemap",
"Zoom" : 8,
"ShowStartMarker" : true,
"Height" : 200,
"Width" : 400,
"MarkerField" : "",
"ClusterLocations" : false,
"ShowEndMarker" : true,
"MultiSelect" : false,
"ShowPathBetweenMarkers" : false,
"ResponsiveLayout" : true,
"ShowRoute" : false,
"ShowRegions" : false,
"RegionLocationField" : "location",
"Type" : "googlemap",
"ShowMarkerTooltips" : true,
"PlannedRouteStyle" : "DefaultMapRouteStyle",
"EnableRegionSelection" : false,
"ShowRegionTooltips" : false,
"PlannedRouteLocationField" : "location"
"Properties" : {
"MinHeight" : 0,
"TabWidth" : 36,
"BGImageRepeat" : "no-repeat",
"ShowExpandCollapseTab" : false,
"ExpandCollapseTabLocation" : "outside",
"TabExpandStyle" : "DefaultTabExpandStyle",
"Visible" : true,
"DisplayName" : "Column 2",
"Style" : "DefaultContainerStyle",
"BGImageSize" : "auto",
"Overlay" : false,
"Expanded" : true,
"TabCollapseStyle" : "DefaultTabCollapseStyle",
"OverlayIsTransparent" : false,
"Z-index" : 10,
"TabOffset" : 0,
"MinWidth" : 0,
"__TypeDisplayName" : "Container",
"TabLocation" : "center",
"Area" : "UI",
"Type" : "container",
"AnimateExpandCollapse" : true,
"TabHeight" : 36,
"Id" : "container-15"
"Properties" : {
"Left" : 380,
"IncludeSpacingInFixedAreas" : false,
"HeaderHeight" : 0,
"PctRow4" : 0,
"PctRow3" : 0,
"PctRow2" : 50,
"FooterHeight" : 0,
"PctRow1" : 50,
"PctRow8" : 0,
"PctRow7" : 0,
"PctRow6" : 0,
"PctRow5" : 0,
"LeftSidebar" : false,
"RightSidebar" : false,
"PctColumn5" : 1,
"Visible" : true,
"DisplayName" : "layout-13",
"PctColumn6" : 1,
"PctColumn3" : 1,
"PrintWidth" : 650,
"PctColumn4" : 1,
"PctColumn1" : 100,
"PctColumn2" : 100,
"PrintMarginTopBottom" : 0.5,
"Rows" : 0,
"RightSidebarWidth" : 0,
"PrintMarginLeftRight" : 0.5,
"PctColumn7" : 1,
"PctColumn8" : 1,
"Columns" : 1,
"Z-index" : 10,
"Spacing" : 2,
"Orientation" : "horizontal",
"__TypeDisplayName" : "Layout",
"Area" : "UI",
"Type" : "layout",
"LeftSidebarWidth" : 0,
"Header" : false,
"Top" : 195,
"IsPrintLayout" : false,
"Footer" : false,
"Id" : "layout-13"
"Properties" : {
"MinHeight" : 0,
"Left" : 0,
"AddToDashboardButtonStyle" : "DefaultAddToDashboardButtonStyle",
"id_index" : 19,
"supportsAutoResize" : true,
"Visible" : true,
"DisplayName" : "Mashup",
"Style" : "DefaultMashupStyle",
"Height" : 618,
"Width" : 1024,
"TitleBar" : false,
"Rows" : 0,
"ConfigureGadgetButtonStyle" : "DefaultConfigureGadgetButtonStyle",
"TitleBarStyle" : "DefaultTitleBarStyle",
"Title" : "",
"Columns" : 0,
"Z-index" : 10,
"TitleBarText" : "Gadget Title Here",
"MinWidth" : 0,
"__TypeDisplayName" : "Mashup",
"EnableParameterEditing" : false,
"Master" : "HeaderMaster",
"Area" : "Mashup",
"Type" : "mashup",
"Top" : 0,
"MashupToEditGadget" : "DefaultMashupToEditGadget",
"Id" : "mashup-root",
"IgnoreWarningsInViewMashup" : false
"Events" : [ {
"EventTriggerArea" : "Mashup",
"EventHandlerService" : "getlocation",
"EventTriggerSection" : "",
"EventHandlerId" : "Things_ExtractData",
"EventTriggerEvent" : "Loaded",
"Id" : "f96261d0-97ce-4932-8e4a-e381f8593444",
"EventTriggerId" : "mashup-root",
"EventHandlerArea" : "Data"
"mashupType" : "mashup",
"DataBindings" : [ {
"SourceArea" : "Data",
"TargetArea" : "UI",
"TargetSection" : "",
"SourceId" : "getlocation",
"Id" : "2fcc0f2b-c624-4ca7-a770-0681f35401fb",
"SourceSection" : "Things_ExtractData",
"SourceDetails" : "AllData",
"PropertyMaps" : [ {
"SourcePropertyType" : "InfoTable",
"TargetProperty" : "Data",
"TargetPropertyType" : "property",
"SourcePropertyBaseType" : "INFOTABLE",
"TargetPropertyBaseType" : "INFOTABLE",
"SourceProperty" : ""
"TargetId" : "googlemap-19"
"Data" : {
"Things_ExtractData" : {
"EntityType" : "Things",
"Services" : [ {
"Target" : "getlocation",
"Parameters" : { },
"APIMethod" : "post",
"Characteristic" : "Services",
"RefreshInterval" : 0,
"Id" : "66ae8d87-33c1-4249-bd39-c608f9a1b25f",
"Name" : "getlocation"
"EntityName" : "ExtractData",
"Id" : "b564705a-051e-4772-8372-a16f32ba424b",
"DataName" : "Things_ExtractData"
"UserExtensions" : {
"EntityType" : "UserExtensions",
"Services" : [ {
"Target" : "GetCurrentUserExtensionProperties",
"Parameters" : { },
"Id" : "UserExtensionInterface",
"Name" : "GetCurrentUserExtensionProperties"
"EntityName" : "",
"Id" : "UserExtensions",
"DataName" : "UserExtensions"
"Session" : {
"EntityType" : "Session",
"Services" : [ {
"Target" : "GetGlobalSessionValues",
"Parameters" : { },
"Id" : "SessionInterface",
"Name" : "GetGlobalSessionValues"
"EntityName" : "",
"Id" : "session",
"DataName" : "Session"
"DesignTimePermissions" : { }
}]]></mashupContent><ConfigurationChanges><ConfigurationChange changeAction="CREATE" changeReason="header : name : updated, projectName : updated, documentationContent : updated, avatar : updated " timestamp="2017-04-24T10:49:58.382+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T11:15:27.805+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T11:15:28.752+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T11:15:36.030+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T11:16:35.021+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T11:16:35.895+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T11:23:26.229+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T11:43:16.781+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T11:43:18.608+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T11:44:29.581+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T11:44:31.394+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:19:48.780+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:19:49.834+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:21:39.418+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:21:40.273+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:24:42.284+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:24:56.497+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:24:57.981+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:31:57.883+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:31:59.275+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:33:39.352+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:33:40.303+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:40:19.964+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:44:02.186+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:44:03.885+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:44:51.041+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:44:52.867+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:45:15.004+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:45:33.638+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:45:34.901+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:48:09.938+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:50:36.532+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:50:37.721+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:54:14.915+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:55:19.035+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:56:21.078+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:56:21.976+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T14:56:22.541+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T15:00:31.741+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T15:00:32.603+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T15:00:33.301+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T15:00:40.546+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T15:00:41.313+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T15:00:56.587+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T15:01:26.525+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T15:01:27.229+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T15:01:42.913+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T15:01:43.660+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T15:01:43.843+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T15:01:45.097+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T15:07:53.329+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T15:07:55.443+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T15:08:22.537+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T15:08:23.276+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T15:11:06.661+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T15:11:33.574+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T15:27:34.965+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T15:27:36.284+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T15:28:46.331+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T15:28:48.762+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T16:38:02.352+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T16:38:03.905+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T16:38:05.011+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T16:41:00.892+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T16:41:41.511+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T16:41:42.651+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T16:41:44.000+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T16:43:21.026+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T16:45:19.026+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T16:45:19.873+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T16:47:03.306+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T16:52:21.730+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T16:54:43.657+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T16:54:56.224+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T16:54:57.076+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T16:56:00.256+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T16:56:01.005+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T16:57:42.685+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T16:57:43.382+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T16:58:23.046+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:00:12.938+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:03:22.819+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:04:13.110+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:04:14.021+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:04:24.664+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:04:25.201+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:05:33.050+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:05:33.926+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:06:05.397+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:06:33.817+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:06:35.029+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:07:06.417+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:07:10.663+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:08:27.376+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:08:27.967+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:10:32.610+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:10:35.204+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:12:17.624+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:12:18.208+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:13:51.982+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:14:46.996+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:14:47.656+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:16:07.645+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:16:12.070+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:16:52.170+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:16:59.033+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:17:52.156+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:17:53.212+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:22:19.026+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-08T17:22:20.225+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-09T14:34:47.774+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-09T14:39:15.329+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-09T14:39:50.069+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-09T14:39:51.328+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-09T14:40:27.807+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-09T14:40:28.884+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-09T14:40:50.689+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-09T14:40:51.580+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-09T14:41:03.760+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-09T14:41:04.473+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-09T14:44:21.807+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-09T14:44:22.910+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-09T14:44:48.754+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-09T16:48:12.752+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-09T16:48:20.676+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-12T14:16:07.124+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-18T16:57:21.368+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-18T17:02:40.658+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-18T17:16:39.195+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-18T17:16:40.047+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-18T17:17:08.559+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-19T09:38:00.001+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-19T09:39:25.459+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-19T09:39:34.175+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-19T10:59:17.815+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-20T09:21:33.812+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-20T09:23:23.905+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-20T09:44:38.666+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-20T09:44:40.132+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-20T09:52:19.345+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-20T10:06:27.210+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-20T10:10:04.074+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-20T10:14:44.643+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-20T10:14:56.298+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-22T09:28:37.980+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-22T11:31:37.664+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-22T11:31:39.435+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-22T14:13:11.666+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-22T14:13:14.248+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-22T14:16:55.551+08:00" user="Administrator"/><ConfigurationChange changeAction="MODIFY" changeReason="" timestamp="2017-05-22T14:33:54.008+08:00" user="Administrator"/></ConfigurationChanges></Mashup></Mashups></Entities>
Dear Ankit,
Problem solved. I made a mistake on the location.longitude equal to the latitude in the location object.
Thanks for your great help!
