Google Map Widget
ketanaga
Google Map Widget
Hi All
I am trying to integrate Google maps widget in my mashup. To do so I have already imported the widget package in Thingworx composer.
To continue using it I suppose we have to enter the Javascript URL with app key under System -> Subsystem ->Platform Subsystem -> Required string to connect with Google for Google widgets field
I am not able to locate the string field
Is there a way around for the same?
Regards
Hello @ketanaga ,
Note: make sure you share the complete ThingWorx version number in future, there are some small differences that may matter.
Going back to your issue: I presume that you use a version of ThingWorx below 8.3.3. In this case, you will not be able to find those connection strings in that subsystem, and you need to insert your appKey in the zip file itself.
The answer is found in the Help Center article that @raluca_edu  shared. Look at the section "Using the Google Widgets 3.0.1 and Earlier Versions" , it's at the end of the article. The widget is also different - you need to use the 3.0.1 Google Maps widget from the marketplace.
PS: I want to use this occasion to remind you that ThingWorx 8.3.x will be out of support in 8th of June 2020. Ideally you should migrate to the latest ThingWorx version to gain advantage of the newest features, bugs and security fixes. I believe version 9.0 is planned to be available June 2020 (https://support.ptc.com/cs/product_calendar/PTC_Product_Calendar.htm )
7 REPLIES 7
ketanaga
(To:raluca_edu)
Hi
I have followed all the steps mentioned in the links, but still I was not able to achieve what I am trying to i.e the services under Platform Subsystems to check the API key and the string input field under Configuration in Platform Subsytems
Regards
Ketan
slangley
23-Emerald II
(To:ketanaga)
Hi @ketanaga.
Did you set up an account with Google for obtaining the API key?
--Sharon
ketanaga
(To:slangley)
Hi
Yes I have the API key and the javascript url
Regards
ketanaga
(To:ketanaga)
Hi @slangley
Is there an update on the mentioned issue
I am using Thingworx 8.3
Regards
Hello @ketanaga ,
ketanaga
(To:VladimirRosu)
Hi
Thankyou for the solution
Regards
