Google Maps Widget Modal Popup Bug
ashleyg
Hi All,
Just wondering if everyone else is experiencing the same issue.
I am using ThingWorx 7.2 and Chrome for displaying a Google Maps widget on a modal popup (static mashup) along with some other widgets (labels, list etc).
When viewing this modal popup, through a Navigation Widget, the Google Maps Widget tends to display fine. However if I close this modal popup and reopen again by clicking the Navigation Widget the Google Maps Widget disappears, this happens for all subsequent times I open the modal popup until I refresh the page. I have also noticed this problem happening in previous versions of ThingWorx (7.1, 6 etc).
I have tried this using FireFox and the problem is even worse as I cannot get the Google Maps widget to display at all on a poup.
This is a rather annoying bug as it means that Customers would have to refresh the page everytime they want to open a modal popup (which may be several times on the same page).
Is anybody else experiencing this issue? Is there a workaround or do I need to open a case to PTC?
Many Thanks
Ashley
ankigupta
(To:ashleyg)
Hi Ashley,
I can reproduce this on ThingWorx version 7.2.2 with Google map added in a Static Mashup and opening this Mashup as a Modal Popup.
Please open a case with PTC.
Workaround would be to use Google Map in a responsive Mashup.
Ankit Gupta
4 REPLIES 4
ankigupta
(To:ashleyg)
Hi Ashley,
Ankit Gupta
Many thanks Ankit!
Can you confirm that the Google Maps Widget will work in a responsive modal popup? If not I'll try myself.
Ashley
ankigupta
(To:ashleyg)
Ashley,
Yes, I added Google Map widget in a Responsive Mashup and then used it in a modal popup of Navigate widget. It worked fine for me.
Ankit Gupta
Thanks Ankit!
