I am using GRID from Thingworx 9.3.6, I have given the background color of the Grid Header in the Style Properties, as you can see in the below.
But in the Runtime, it still shows, white in the background of the Header.
It does work properly in 9.3.6 & 9.3.7
Could you please check if any custom CSS or custom widgets affecting the grid
/VR
hi @Velkumar ,
I tried it in a separate mashup, too, but the same result. Do you have Custom CSS we can apply for the header background for the GRID?
Is there a Master Mashup assigned ?
Are you trying to set the Column background color or the Grid Title background color. They are set in different parts of the Theme.
Have you modified any other theme items which apply to the grid?
Hi @PEHOWE ,
I am using this as a Nested Mashup in a Parent one; it looks like there is a CSS conflict when I use it as Nested; I can see the Header background colour when viewed Individually.
@PEHOWE, I am trying to add the background to the Header Mashups.
Hi @pshashipreetham ,
You can try inspecting element and play around with styles and computed tabs, it will show what CSS is being applied and from which CSS class, then you can export all the involved mashups (xml) and check for that class.
Alternatively, you can define a class in that particular mashup CSS section and assign it to class property of grid then using Pseudo selector and important clause with CSS, it may help.
