Grid Widget without Enable Sorting setting (TWX 9.5)
ZbigniewK
With TWX 9.1.5, I've used Grid advanced widget to present infotables in mashups. If I wanted user to allow change sorting criteria, I ticked "enable sorting" in widget setting, and had buttons for operator to change sorting criteria (as far as I remember, it still needed to define service to make sorting).
With TWX 9.5, I use Grid - and have no setting called "Enable sorting". Was the name changed? Is this setting still available? If not - how can make interface for operator to allow him to set which column should be treated as sorting criteria, and also change it ascending/descending?
It's configured per column in the "Configure Grid Columns" page (green cog icon). There you have "Sort Button" and Initial Sorting option.
The full process is described in the help.
https://support.ptc.com/help/thingworx/platform/r9/en/#page/ThingWorx/Help/Mashup_Builder/Widgets/Grid_SortingAndFilteringTheGridData.html#
