HTTP Error 404 - ThingWorx Composer - 8.5
Gizem_Turan
8-Gravel
I am facing suddenly the issue that I can not open the Composer, I am getting the message "HTTP Error 404. The requested resource is not found" in Google Chrome.
I have just installed (separetely from Thingworx) SQL Server and Reporting Services on the same machine where ThingWorx is also installed.. I do not know if this is causing the Problem??? Because my ThingWorx platform did work before.. The database is Standard h2 like coming from the Installation.
I have restarted tomcat several times - but it did not help.
Attached is a log file whih I found in tomcat/logs ...
Hi @Gizem_Turan ,
The issue was occurring due to improper permissions on the ThingworxStorage folder
We provided Full Access to the Users group of Window OS under security tab and after that we were able to login in thingworx.
Himanshu
9 REPLIES 9
Hi @Gizem_Turan ,
Looking at the logs, it seems like thingworx database is read only and due to which application is not getting started.
Can you check the database status by creating any test table in thingworx database.
Also you can try restarting database services.
Himanshu
Hello @hchanana,
thank you for your answer!
I am very new to ThingWorx and one of my colleagues has installed and configured it. He is not available at the moment.. I do not know how to create something in the database without using the Composer (which is not Opening regarding to my issue).
Can you describe me the steps for it? And which services belong to the database?
Another Point is that on Friday after I wrote this post, I stopped all SQL Services (which were installed separately of ThingWorx) and after that it is possible to enter Login data when loading the Composer Webpage, but after I enter it, I am receiving now a "500 unexpected error - contact your System Administrator for more Details"..
Just for additional information.
Thank you very much for your support,
Gizem
Hi @Gizem_Turan ,
Can you please share complete logs from your C:\ThingworxStorage\logs folder and platform-settings.json file from C:\ThingworxPlatform folder
Himanshu
Hello @hchanana ,
attached you can find the files. I hope they help you to find the source and solution of my problem.
Thank you in advance!
Gizem
Hello @hchanana ,
could you check the logs?
Gizem
Hi @Gizem_Turan ,
As you mentioned that you are getting logging prompt after stopping SQL services, it means our database is working fine now.
Can you please share the latest logs as the logs provided does contains only about readonly database issue.
There is nothing related to "500 unexpected error - contact your System Administrator for more Details".
Please follow below steps to grab logs:
Stop tomcat --> Clear logs from ThingworxStorage\logs folder --> Start tomcat and try to load the composer again.
Himanshu
Hello @hchanana ,
thank you for analyzing. I followed the steps you mentioned (stoped tomcat, deleted logs, stared tomcat and Composer). So attached the "new" log files, which were generated when I opened Composer.
I could see in the files several times the entry "SCIMProvider initialization failure.  Thingworx Server is not running".....
But I have started tomcat Service..
Gizem
Hi @Gizem_Turan
I have opened a support case on behalf of you to investigate the issue at your end. You will get an email for the same.
Himanshu
Hi @Gizem_Turan ,
Himanshu
