Help:Tree widget without scroll bar?
kqian-2
question: I created a tree, but there is no scroll bar when I open the node?
                So I can't choose the node below.
8 REPLIES 8
supandey
(To:kqian-2)
Kitty, this is which version of ThingWorx? Is this a Responsive Mashup?
The version is 7.2.0-b155  and  it is a responsive mashup.
ankigupta
(To:kqian-2)
This issue is not reproducible in ThingWorx version 7.4.0.
I will try to test it in ThingWorx version 7.2.0 too. In case it is a bug in 7.2.0; it is already fixed in 7.4.0.
Thank you!
I will be waiting for your test!
ankigupta
(To:kqian-2)
Hi Kitty Qian​,
I just tested and found that it's a Bug in ThingWorx version 7.2.0.
Thank you very much!
supandey
(To:kqian-2)
Just for the completion sake on this thread this is the Jira ticket PSPT-2827 filed for this issue on 7.2 and it not fixed yet. Interestingly though Ankit Gupta​ its still open for the 7.4 build
ankigupta
(To:supandey)
Sushant Pandey​, As per my testing, scroll bar is showing when Tree widget data goes out of current view in Thingworx version 7.4
So, could you please update Jira that it seems fixed and ask R&D team to test it in version 7.4
