How can I implement service to importing/exporting Entity
kpark1
I found ReadEntityAsJSON  service to export entity information. BUT It's not export delicate information(ex) stream data)
Is there supporting system to importing and exporting Entity?
Thanks.
ttielebein
(To:kpark1)
Saving to the repository is essentially what happens when you export to source control. There is probably a way to do that via service script... yeah, something like this:
http://localhost/Thingworx/Resources/SourceControlFunctions/Services/ExportSourceControlledEntities?Accept=application%2…
ttielebein
(To:kpark1)
Have you seen this KCS article on this? Notice the "WithData=true" in the URL. I hope this helps!
Thanks Tori
It DOES work.
but I have 3 questions
1. How can I import each entity(not entities) with data in script?
2. Can it save in repository not in exports?
3. How to import entity in Service from script
ttielebein
(To:kpark1)
There is a REST call for importing as well, though I don't know the exact syntax, but it is something like http://localhost/Thingworx/DataImporter
I will try to find the time to figure out what parameters to use for this, but I wanted to get a comment back to you sooner in case I don't get that chance.
Thank you for your pleasure Tori
I hope you find it.
ttielebein
(To:kpark1)
