How can I view a 3D model in thingworx ?
SD_10134497
and also can i show live data in the 3D model.
Hi @SD_10134497,
As you probably know, ThingView widget can be used to visualize 3D CAD model which comes with Windchill Navigate and other products as smainente replied in your original post.
If you want to show live data, you can use other widgets to display the properties of the remote asset in ThingWorx Mashup.
Alternatively, you can use Vuforia Studio to create an AR experience to show live data from ThingWorx as well as the 3D model.
Tony
Hi @SD_10134497. Can you take a look at the article below?
https://www.ptc.com/en/support/article/CS336207
Rocko
(To:SD_10134497)
You have received a reply on this question previously here: https://community.ptc.com/t5/ThingWorx-Developers/I-have-a-pvz-file-I-want-to-import-in-Thingworx-and-visualize-a/m-p/1010306#M69501
it is preferred to keep follow up questions in the same thread, no need to open a new one.
Hi @SD_10134497,
Tony
Hi @SD_10134497,
It appears that a response to this post answers your question. For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Tony
